I have a street stock car, a metric chassis, all stock mounts for control arms, shocks, and springs, no wt jacks. I use shims in the lr to help adjust my lr bite, but when i had it on scales yesterday and i would remove shims from lr it was adding bite, not reducing bite, anybody had this problem before?
Scaling Questions, help please!
thats what i thought, i will have to get it on scales again and see if i had something screwed up, should i remove or unbolt the shocks when scaling? has qa1 oil shocks but the lr is a gas shock, also should adding shims change the ride hts? where is the best place to measure them, have heard just from ground to bottom of frame and also between rear end and frame over rear end.
The right way is to pull all the shocks. Gas ones always pull them.
Adding the shim in one corner will change the height in that corner.
Measure between the frame and the rear end / frame and the a arm.Last edited by DaveBauerSS6; 09-04-2012, 12:59 AM.Gator Engineering
