Heads vs Heads
  • Eamsnewbie
    • Sep 2012
    • 48
    Heads vs Heads
    I've only got two options; pull some vortect heads from the junk yard or use some 461 *camel humps* heads. Which is the better choice? And if you went with the vortec heads what intake would you use?
    thanks
  • Dirt Knife
    • Jun 2012
    • 147
    heads
    Cast iron Vortec intake
    dont redrill gen 1 intake its junk
    • dirty white boy
      • 1238
      vortecs are the better head...
      white trash motorsports
      • Egoracing
        • 4852
        Originally posted by Dirt Knife View Post
        http://www.circletrack.com/enginetec...cylinder_head/
        The only VORTEC intakes that were not fuel injection were marine and many rules do not allow marine parts.
        • Eamsnewbie
          • Sep 2012
          • 48
          I didn't think that far ahead, so
          A Holley 600cfm carb will not work on a standard Vortec intake? Guess I need to look into that
          • dirty white boy
            • 1238
            whats the intake rules at your track,..bout any intake can be drilled to work with vortec heads...
            • Eamsnewbie
              • Sep 2012
              • 48
              This is for bomber class INTAKE:
              A. Cast iron or aluminum factory production low profile intakes permitted.
              B. May run aftermarket aluminum dual plane intake manifold. ONLY intakes permitted to use are Edelbrock 2101, 2701, 5001 or 7101. Weiand 8120 or 8150. Summit Racing 226008, 226012 or 226014.
              C. Vortec Heads may run Edelbrock #7116 or 2116 or GM # 12366573 (same as on 602 crate engine), Weiand 8120 or 8150. These are the ONLY intakes allowed with Vortec Heads.
              D. NO porting, polishing, squaring, or epoxying of intake ports, plenum, or runners. NO Rmilling or hogging out plenum.
              E. One 1” carburetor spacer or one 1” adapter plate permitted on all engines.
              F. Ford Motorsport low profile aluminum intake permitted.
              Or the hobbY class
              INTAKE:
              A. Any cast or aluminum dual plane intake. Edelbrock #5001 allowed.
              B. Open plenum intake add 100lbs.
              C. NO port matching. NO porting, polishing, or epoxying of runners permitted. D. 1” Carburetor spacer allowed.
              CARBURETOR:y class
              • dirty white boy
                • 1238
                #7116 would be my choice!!
                • twisterf5
                  • May 2012
                  • 334
                  what is the carb rule. 650 or less use 461 you can cut them more and get better bottom end. if you can run a 750 then use vortec . we built 357 in 09 and made better power with 461 with the 4776 carb rule we had. would rather match heads and carb and get the best that i can than have a head to big for my carb rule.
                  • Eamsnewbie
                    • Sep 2012
                    • 48
                    carb rules is 600cfm.
                    • carowner73
                      • Dec 2009
                      • 174
                      did your vortecs have 1.94/1.50 valves though
                      and on his weekly rules, he is on a .460 lift hydraulic rule
                      both will highly limit the advantage of the vortec
                      Plus the vortecs with 1.94/1.50 from the factory are rare....plus the allot more likely to crack
                      Putting Seats in big valve heads is asking for trouble
                      • Eamsnewbie
                        • Sep 2012
                        • 48
                        yes there is a 450 lift rule i believe, we went through all the engine stuff he had laying around. we found some 882 heads. they've already been worked.
                        so i think i will go with them.
                        you coming to the state race?
                        • Egoracing
                          • 4852
                          I agree with stock car, we ran a 450 lift 4412 class and the vortec heads were about 20-25hp better than the set of 461x heads that we had on the car. The Vortec were good enough that we tried them on our modified motor (We also got a weight break for stock heads) and made a little more power than the untouched (old style) BowTie aluminum heads we were running. If you have a competent machine shop and do not cook the heads they will run without problems.
                          • dirty white boy
                            • 1238
                            the vortech headed cars at our track run so much better than dubble hump heads our track added 100 lbs to cars with the vortec's an them bow tie vortecs are plum bad!! the bow-techs come in 2 runner sizes,...sure making the older heads useless if'in ya wanta be competitive..
                            • Eamsnewbie
                              • Sep 2012
                              • 48
                              Thanks for all the input
