There are different setups that can win the same race. That said:
I like feel of the chassis higher in the rear. It raises the stock frame mounts in relation to the rear end. I run the lowers on the rear end about middle holes on Jeff's mounts. I vary the rear holes for rear steer. On our only track for IMCAs, it works well.
Shocks are difficult to test by hand. If the RF shock is weak it will allow the car to roll over and bottom out the RF. I would go to the 3 off in hot laps and then switch the front shocks for the heat IF they are the same. One change at a time.
On a stock rear suspension, I work on the front end to steer the car into the corner.
I've never ran that much bite, 50 to150 is the range. I'm not sure how that would handle??
