Axle bearing?
  • SRT17
    • 172
    Axle bearing?
    I am having trouble finding the right bearings for my ford 9" axles. F208A-KK is the number on the bearing. Auto parts stores have no clue what bearing it is. Can someone tell me what cross references the number.... Thanks
  • Dirt Knife
    • Jun 2012
    • 147
    info
    F208A-KK bearing
    Part Number: DL514003 Auto Zone
    1970 F100 P/U W/9"
    • SRT17
      • 172
      I went to AZ today... They said their wasn't a cross reference for it..... I will try it with the numbers... Thanks....
      • Eamsnewbie
        • Sep 2012
        • 48
        dont ever go to auto zone, go to oriellys, they can get it for you! when i go in there tonight i will report the bearing numbers. i want to say its an a-9 or a-6 national bearing.
        • Eamsnewbie
          • Sep 2012
          • 48
          BCA m88048 10 bucks
          • SRT17
            • 172
            That is not it.... Mine is a sealed type not a tapered bearing. I went to their web site. It looks more like an A20...
            • dirtman45
              • Dec 2010
              • 104
              Does it look like this kind?
              • SRT17
                • 172
                Yes...But I don't think it has a seal on the outside dia.... I will have to check..
                • Eamsnewbie
                  • Sep 2012
                  • 48
                  A20 is a ford bearing 73-86 Lincoln 74-77 or mercury 74-79
                  • dirtman45
                    • Dec 2010
                    • 104
                    The O ring seal is what keeps the lube in the rear end housing. It usually will work fine and slip into the housing end fine. You just need to get the bearing with the correct ID.
                    • Eamsnewbie
                      • Sep 2012
                      • 48
                      Did you find the correct bearing? If so, what was the number?
                      • SRT17
                        • 172
                        I got some today.. 88128R... The OD is the same. Not sure about the ID. They were close to what I could measure. I haven't removed the old one yet... Thanks...
