Spindle question?
  • Derks88
    • 52
    Spindle question?
    If I put a spindle on my car that is 2" shorter height from my stock spindle, and the steering arm is 1.5" shorter than stock. What should I expect? Should I change other things in the suspension?
  • speedbuggy
    • 259
    you should expect a LOT faster camber gain/change. This could make that wheel more sensitive as far as dialing in the initial static camber/caster settings to get the best tire contact patch after dive and roll.
    I would think a good tire temp pyrometer would be a MUST if you were going to do this.
    • vaoutlaw
      • Jul 2009
      • 159
      that wont work on the left front,bumps too far off,roll centers too far right,and static camber would be terrible.
