Camaro info
  • Ferg58
    • 519
    Camaro info
    Will a metric spindle work on a 70's Camaro??
  • 72Dubya
    • Sep 2011
    • 504
    I believe that most 70'-81' Camaros use the same ball joint measurements as 73'-88' Midsize GM Metrics. I think that the only thing is the metric spindle is shorter than the Camaro spindle, and it may not have the strength compared to a Camaro spindle as well. You can use an adapter to use Metric calipers on a Camaro spindle though. I believe Harris makes one.
    #72W U.M.P Stock Car
    • Ferg58
      • 519
      hey Kaleb
      If the ball joint to ball joint is the same . I am not sure what you mean by shorter?
      • DaveBauerSS6
        • Jun 2010
        • 566
        The metric spindle is shorter. If you install it on the camaro clip the top a arms will be almost flat, depending on your ride height. I don't think that howe sells a ball joint that is long enough to correct it. I ran the metrics on the camaro one season. I added a 2" riser to the top of the metric spindle to get the roll center corrected. The down side is, the racing is a full contact sport in California and it was a pain to replace them. There was a good weight loss though.
        Gator Engineering
        • 72Dubya
          • Sep 2011
          • 504
          Exactly what Dave said. Stand them up side by side and you will see a height difference in the two.
          • Ferg58
            • 519
            What I am trying to get done is change to a 5x5 wheel pattern. I dont know of any hubs that are 5x5 for Camaro. Or is there???
            • bobdoo
              • Apr 2011
              • 39
              Speedway motors had 5on5 rotors for camaro. I changed mine 2 yrs ago. Had to change outer wheel bearing to match.
              • 72Dubya
                • Sep 2011
                • 504
                I used these rotors on the sportsman to make it a 5x5. It had a Camaro front clip. But, if I remember correctly, we had to use a different outer bearing than you usually would to make it work on the spindle.
                • Ferg58
                  • 519
                  Hey thanks Guys
                  • kc92
                    • Nov 2007
                    • 174
                    hubs
                    u can also use older impala spindals and lowers and i think chevy astro vans
                    • 500BOMBER
                      • 762
                      Ditto on the Impala spindle. You also will have a 12" rotor('91 and up for sure) instead of an 11" rotor in that swap.
                      Old enuf to know better, still too young to givadamm.
                      • Anderson0
                        • Nov 2012
                        • 6
                        Hi
                        today i have a question which is that I have an 83 z28 camaro and its light blue with silver stripes. It has t-tops also. Did this blue come stock? If so what color blue is it or where can I find out? Also, it has a blueish color fabric interior and I'd also like to know the name of that color is. Is there a web site that says the color combinations that came with the car?
                        mining camps|industrial caravans & portable accommodation for you
                        • krazyracer10
                          • Jun 2011
                          • 17
                          i have the impala spindles and on mine to make it 5x5, they bolt right up but i had to take a tapered reamer to the upper ball joint hold to be able to use a camaro ball joint. The impala spindles and brakes are much beefier though. The camaro tie rods bolt right up to it and the geometry is the same
                          Britton Settle #10
