I run a 4412 on a 383 in a dirt street stock, i know of a few guys that are running the E85 fuel, just wondering what you guys think about this fuel and running it in a race motor, i like the idea of E85 being about half the price of race fuel, and ive heard you can gain around 25hp and that it runs cooler. I also heard of a few guys burning down their motors because of this fuel. Just wondering what everyone elses take was on this issue, and what others had heard pro/con wise.
E85? Pros/Cons
Definitely run a true E-85 built carb! Cost of E-85 is soon to rise due to tax breaks ending for manufacturers. Only real problems I have heard are from guys trying to run modded gas carbs and from fuel that wasn't blended right. Purchase from someplace thats trustworthy.
Check the SG
One thing you have to be aware of if you're buying the E85 from the local gas station is that the fuel you buy will not be exactly 85% ethanol. EPA, DOT and I think a couple other alphabet agencies granted the fuel providers leeway in the ethanol to gasoline ratio over the seasons and the availability of the base ethanol. If I remember correctly in the summertime the percentage could be down to 75% ethanol. To know for sure you'll need to check the specific gravity of each batch of fuel you buy. I would suggest that the racer should buy the E85 in large batches (maybe a months worth at a time) to reduce the number of times the SG needs to be checked.
I know a lot of 1000 hp+ drag racers than run e85 and love it.. Everything from nitrous big blocks to twin turbo small blocks.
If you burned up a motor on it you didn't know what you were doing and it's your fault the the fuel..
IMO the key things are to get a GOOD carb, not a conversion kit project or generic E-85 shelf carb, a good pump, and test the fuel. If it's set up right and you check your fuel you'll be just fine. The people I've seen have problems were trying to cut corners to "save money". Good stuff and diligence doesn't cost that much more, an engine does.
Even though E-85 is cheaper, it burns off twice as fast than normal racing fuel. So, whatever money you save in price per gallon will be lost in gallons you will have to buy from what is being burnt. If your track allows it, I would try switching to an oxygenated race fuel, like VP CHP. Usually you will have to tune your carb richer, but you burn the same amount of fuel, but gain a lot of HP and Torque. I know that if you send your 4412 to Willy's and say that you are going to be burning an oxygenated fuel, they will tune and dyno your carb for you.#72W U.M.P Stock Car
Respectfully that's not right either. Methanol will use twice as much. E-85 which is 85% ETHANOL does not. Two different fuels. Look at bsfc numbers to see the difference. I think that the amount of misinformation contributes to the "problems" people have with using it. If your stuff is right, it works and costs less.Last edited by 50j; 11-25-2012, 04:10 PM.
I have to agree there, I hear at most 25% more use and that is most likely high. The most fuel (gas) I have run through on a 50 lap race was 11 gal. had tons of caution laps we most likely ran 75+ total.Originally posted by 50j View PostRespectfully that's not right either. Methanol will use twice as much. E-85 which is 85% ETHANOL does not. Two different fuels. Look at bsfc numbers to see the difference. I think that the amount of misinformation contributes to the "problems" people have with using it. If your stuff is right, it works and costs less.»»*†HÀ†§ HÓ††™««
puauvr moncler jackets
vqs5
GpxpCFZS ugg boots outlet
kivsDKGoq http://www.menafn.com/menafn/canadagoose.asp
vppaupsmjl ugg boots clearance
VEVxUaptu qacndm cheap canada goose
XiqFTTAHmul HvhgIDRK cheap canada goose
knliAEKyz PxgzRFZU http://www.menafn.com/menafn/moncler.asp
dzyyNOShs
