cage placement
  • newguy
    • Jan 2011
    • 170
    cage placement
    how far back on a metric frame can you go? rules do not say anything about it. And would you go with a perimiter frame? or an offset frame?
  • RW57
    • 662
    As far back as you can imo. We found an older car for my son to start in last year camaro clip square tube middle metric rear rails 3 link in rear. We have a hard time getting enough rear percentage with out being over wgt car must weigh 2900 with driver there is talk of cutting wgt down to 2800 this year cage is set foward and this kills us as far as getting rear perentage . Keep in mind car was a Monte Carlo in its heyday and now cage has been cut down so now it wears a latemodel type body my son is 6 ft 2 and he is really cramped in car also because of cage being foward. If rules do not give a measurement then it is not a rule imo use it to your advantage if you do not you can bet the competion will.
    • fattboyee
      • Jan 2011
      • 22
      i thought about this too but our cars were getting rediculess with where the cages were getting setback to. our new rules say the driver seat must be in front of or even with stock front doors rear plane. so seat must be pritty much in stock location.
      the most peacefull time is sitting in the staging lane strapped in helment on and waiting for the green light to move on track.
      • newguy
        • Jan 2011
        • 170
        well right now i have a bare metric frame. I dont have a rear end yet so i really have no idea how far back to set cage before i start running into clearance issues with the LR tire.
        • 3kstreeter
          • Jan 2010
          • 22
          i don't know how the main cage would get into the rear tires but there is a body mount hole on the frame that most put the main cage in. you can go farther back but the frame starts to turn in after that piont and the main cage starts getting too narrow. you can move it behind that hole about 3 or 4 inches with out any problems.
          • keithbaker
            • 121
            Our rear hoop sits at the hole where you would put the bolt in for the rear lower control arms. Not sure what the rear % is right now but I know it wasn't an issue when we had it on scales. Also, plenty of clearance.
            • buterbaughb1
              • Feb 2010
              • 90
              the further back the better..mines too far forward and its a HEADACHE and a ton of lead to get your percentages. My rear hoop is placed right before the frame kicks in.
              Just playin' in the clay
              • newguy
                • Jan 2011
                • 170
                i have seen a guy use that body mounting hole, they put a peice of 1.5 in the hole, then 1.75 over the top, but it just seemed that it was to far forward. I realize that the frame turns in, I dont see that as an issue with a little creative engineering. thanx for all of the responses guys.
                • bushracing67
                  • Oct 2007
                  • 904
                  • newguy
                    • Jan 2011
                    • 170
                    thanx bush thats exactly what i was looking for, do you have a driver side shot?
                    • bushracing67
                      • Oct 2007
                      • 904
                      nope, however it is sitting in the garage bare, i will try to get a couple more pics this week
                      • steveshawjr
                        • Jan 2008
                        • 430
                        ive seen guys start with a old modified and just reclip the back with the stock ralis upto the rearend like bush car has
                        id also loo kat sports mod photos most of them have to have the same idea see how there getting there cage back so far
                        62 mini mod
                        • steveshawjr
                          • Jan 2008
                          • 430
                          some sports mods
                          lots more at
                          62 mini mod
