cooling duct work
  • 9car
    • Jun 2012
    • 59
    cooling duct work
    do many of you guys run duct work from the nose piece to the radiator? i have a nose that looks like one you would see on an asphalt late model where the cutout for air inlet is low on the bottom , i am wondering if i try to use that spot down low is it going to be effective or just pick up dirt and mud ? what experince have you guys had?
    thanks for any help
  • istock11m
    • Sep 2012
    • 82
    It will put more mud in the rad. Good shroud, pulleys,fan, and pump.
    It'll be fine
    • 9car
      • Jun 2012
      • 59
      thanks , those areas i have addressed, just looking for something extra. would you leave the nose completely solid ?
      • hnamea
        • Apr 2011
        • 81
        My nose is solid and I tape up the bottom 5-6 inches of my radiator to keep mud out. I run a stat to get up to temp.
        How do you manage that . we run a 2 pass radiator and still run around 195 to 200
        • Racer96m
          • 425
          My nose was always closed. Keeps dirt out of rad. I had a hard time getting above 170 and would also tape bottom of rad to get heat. You need a 5" strip of plastic hanging down below the rad for an airdam. That will feed the air from under the nose. Need to have a tight fan shroud and 1 to 1 pullies. I ran a double pass rad, no ristrictors. I saw 200 once on one of the hottest nights of the summer.
          Dave.
          • SRXSRULE
            • Jan 2011
            • 217
            Go back to a GOOD single pass and fix the rest of your system. Double and triple pass radiators are a joke. All they do is increase system resistance and make your water pump work harder and rob more HP.
            A stage 3 stewart water pump, 1:1 pulleys, and the correct fan and shroud will make all the difference in the world.
            Quality also varies greatly in radiators. Eric
            • 9car
              • Jun 2012
              • 59
              thanks for all the info guys, what if we switch gears here and talk about quality radiator. i have a griffin , thoughts..... shoot. 200deg i wouldnt have a problem with .
              • MM90
                • Oct 2010
                • 422
                195-205 is perfect, when you get over 220 is when power drops off. I wish my old stock car would have been at 210, but most nights it would get around 220.
                • Werflus
                  • Mar 2011
                  • 7
                  Had holes in nose with screen covering them . Made a cover that was held on by two wing nuts, ran that for hot laps and heats then for main ( dry & dusty ) removed the cover worked well.
                  • istock11m
                    • Sep 2012
                    • 82
                    How old is the radiator? They get plugged up with fine dirt and all the little fin dings add up. I change mine every season, unless forced too earlier!
                    It'll be fine
                    • Racer96m
                      • 425
                      Thats a good point. I like to remove the rad every 5 races and clean it out real good. If you drop it on the floor from a couple inches, you will be amazed how much fine dirt you can get out. It ends up being several pounds, and that is from a rad that looked clean and was blown out with an air valve. Some people soak them in a kiddy pool to loosen up all the dirt. Keeping it clean is a big key to how it works.
                      Dave.
                      • SRXSRULE
                        • Jan 2011
                        • 217
                        Ive had very good results with Northern radiators. My last one was 4 years old. I wash them out every week with a long flex head sprayer, the kind you would use to water flowers. It has a shower head design and it flexes which allows you to reach into all the corners. I use hot water and work from the top to bottom. The fine silt dirt just rolls out.
                        I use a piece of plastic to block off about 6-8" of the radiator to help keep temps up. I like that better then tape so I can remove it quickly each week when washing.
                        The fan, and style of shroud also play a key role in cooling. The big 4 blade that lots of guys say is a must have is not needed. I tried 4-5 different fans on the dyno and the one I use only takes 6hp to run and I still stay way cooler then I need to be. Eric
                        • 9car
                          • Jun 2012
                          • 59
                          the radiator is new . i am just finishing up the car so it hasnt been raced yet, i am just trying to cover all my bases . cheaper to get it right now than to waste a trip to the track and find out something isnt right , i just dont want a DNF for cooling(or anything else for that matter) issues.
