Rear axle
  • mclendon
    • Jan 2010
    • 60
    Rear axle
    Will a slightly bent axle flange cause alot of problems on a 9 inch ford
  • ToddSmith16
    • 2854
    What are your problems/symptons?
    • mclendon
      • Jan 2010
      • 60
      Just checking everything on rearend and noticed the left rear flange where the wheel bolts on was slightly bent have not ran this rearend yet didn't know if this would cause any problems
      • MM90
        • Oct 2010
        • 422
        If the flange is bent, then I would guess the tube is tweaked as well.
        • shadowj38
          • Jul 2011
          • 161
          i have put axles out of a street car in my lathe that run out. it may have came from the factory like that
          • Wsharp26
            • Nov 2012
            • 13
            If you have to beat the axle into the housing dont even try to run it the housing is bent. I blew up two gears once because of this
            • Racer96m
              • 425
              If the flange is bent, the wheel will wobble. Jack it up and run it in gear and see how bad it looks. Eventually the flange will crack where the axle meets it. have to keep a close eye on it.
              Dave
