Street Stock setup help
  • jmd98
    • Jan 2012
    • 5
    What is a good "starting point" on chassis corner weights and percentages? Running on a mild bank 1/4 mile dry slick track and am having issues. Our weight rule is 3000lbs. The only way that I can get any rear percentage (49.2%) is to be 250lbs overweight. If I take out any weight then I am closer to 47%. What left side % ? I know this is sort of a general question.
  • checkersorwreckers
    • Jul 2011
    • 74
    52 rear 52 cross 52 left
    • setup479point2
      • Feb 2013
      • 188
      My first thing would be to put the front half of car on a diet. Look and see if there is anything that can be lightened. My metric car is 2800 lb. with driver(280 lbs ) and 125 pounds of lead and 51% rear.
      • jmd98
        • Jan 2012
        • 5
        Thanks. The problem is that this is an older car and the main cage is where the weight is. Not a whole lot left from the firewall forward. Motor is setback with ball joint even with #1 plug and aftermarket firewall. I know I can about 10 or so more off of the front. I think that the best I can get with this car is around 47-48% rear. With that being said, how much left side weight and cross weight should I consider to be in the ballpark?
        • setup479point2
          • Feb 2013
          • 188
          What kind of car , metric , big gm , leaf ? Checkersorwreckers numbers are fine to start , if you don't have alot of HP you can run less rear.
          • setup479point2
            • Feb 2013
            • 188
            What kind of car , metric , big gm , leaf ? Checkersorwreckers numbers are fine to start , if you don't have alot of HP you can run less rear. Anything you can take off from the rear axle forward will help.
            • dirtman45
              • Dec 2010
              • 104
              If metric we ran 55 to 56 % left side weight and around 54% cross.
              • jmd98
                • Jan 2012
                • 5
                Sorry, its a metric chassis. Running a 408 with a 6.90 final. Just for grins I removed 200lbs of lead from the rear and I ended up with 48% rear, 51%left and 50% cross. With the lead I have 50.6% rear, 52% left and 50.4% cross. Thanks for everyones help!
