One of my sponsors changed logos and gave me new lettering ect. What's the best way to remove vinyl lettering from a painted surface?
taking lettering off
Try just pealing it up, sometimes it will come right off. A little heat if it doesn't want to come up will help. Your worst problem is if it leaves adhesive residue where the decal was. Rubbing alcohol will take that off but it takes a lot of elbow grease. WD40 will also remove the residue but you will then need to really clean that spot good or your new one won't stick.
They also sell a product called "sticker off" for removing the residue.Last edited by dirtman45; 09-15-2013, 06:54 PM.
Carburetor cleaner! You have to be fast or it will remove the paint, too, though.
Maybe not such a good idea...
I just took some numbers off a old car that has sat for a few years. It sat in the sun all day and I got them started with a single edge razor blade. I pulled on them close to the metal, working them in a rolling motion from side to side. They came off pretty easy, even the adhesive.
Heat is all that is needed, even after sitting for years. No rubbing or chemicals, they come right off.
