shackles or sliders
  • brian-micheal
    • Oct 2013
    • 29
    shackles or sliders
    what is better on slick tracks and some rear spring pounds been out of racing for a while son is getting in it with a camero 8 inch racing tires,9 inch this is leaf spring sliders i am asking abiut thanks
  • RaceMentally
    • Nov 2013
    • 137
    Slider right and floated if rules permit along with shackle left with a multi point location along frame to change reaction time of hike and also variable length for amount of cross to add and speed to react.
    When it seems all eyes are on you when you're wearing a new pair of jeans you wonder why everyone thinks you look so darn good in them. When taking them off you notice the sticker still on the pant leg.
    • brian-micheal
      • Oct 2013
      • 29
      Have to run one or the other what you recommend
      • brian-micheal
        • Oct 2013
        • 29
        And what is the best way to install 2x2 rear clip
        • DaveBauerSS6
          • Jun 2010
          • 566
          Mental, I consider the advice of floating bad without some kind of disclaimer. Sounds like a weight loss walker being told to climb Mt Everest. The op is just getting started again, and sounds like limited driving skills. I've ran the floater and was 1/2 second faster than the field in qualifying, but found it difficult to get smooth laps before it was outlawed. I haven't found anyone to consistently run well with it. Tech help is limited. Good easy, safe suggestions are more helpful. Been on this difference of opinion before, but I think I am right.
          Don't misunderstand me, I do well (so far) with a leaf spring IMCA Stock Car and am starting on a IMCA N Sport Mod with leafs.
          Do you cover the floater in your class?
          Just for the record.... Are you/related to Dyno?
          Gator Engineering
          • DaveBauerSS6
            • Jun 2010
            • 566
            And for the record , I agree with the rest of your suggestions.
            Gator Engineering
            • DaveBauerSS6
              • Jun 2010
              • 566
              I use 2x3. This holds the car and rear spring point. Cut it just behind the shock tower.The 2x3 slips int the existing box , then duplicate the existing stamped frame shape wise.
              Gator Engineering
              • RaceMentally
                • Nov 2013
                • 137
                Originally posted by DaveBauerSS6 View Post
                Mental, I consider the advice of floating bad without some kind of disclaimer. Sounds like a weight loss walker being told to climb Mt Everest. The op is just getting started again, and sounds like limited driving skills. I've ran the floater and was 1/2 second faster than the field in qualifying, but found it difficult to get smooth laps before it was outlawed. I haven't found anyone to consistently run well with it. Tech help is limited. Good easy, safe suggestions are more helpful. Been on this difference of opinion before, but I think I am right.Don't misunderstand me, I do well (so far) with a leaf spring IMCA Stock Car and am starting on a IMCA N Sport Mod with leafs. Do you cover the floater in your class?Just for the record.... Are you/related to Dyno?
                Dry slick floating rr is the best thing he could do for a novice driver otherwise he will struggle with grip. Tacky lock em up. I have 2 leaf drivers currently I do this with and even though the skills aren't there they hold their own in dry slick conditions because thy do not over drive the car and have plenty of drive on exit. Tacky we lock them up and decrease cross in the car. We also slide 100-150 lbs from left to right practice, heat and feature. If you're asking if I am related to dynoman the answer would be no. I hope that was not an attempt to suggest I'm like some of the so called "trolls" I've read about on this site.
                • DaveBauerSS6
                  • Jun 2010
                  • 566
                  We agree to disagree. Cool. Thats what makes a horse race.
                  No on the troll deal; I would make it clearer if I felt so.
                  You have similar traits as dyno.
                  And your class?
                  Gator Engineering
                  • DANNY
                    • 791
                    We can float then on the west coast and pretty much they all have em locked up. As Dave said it's too unpredictable lap to lap thus causing more trouble then helping. Most guys run the Chrysler leafs and "work" em but that's another deal all together. *WINK WINK*
                    Find a guy that runs/ran them and is willing to teach you as it's better to see it then read it and you'll be unstoppable. JMO
                    »»*†HÀ†§ HÓ††™««
                    • brian-micheal
                      • Oct 2013
                      • 29
                      what do you mean by floating is there pic or the sliders you by from day or speedwat with the bearings or nylon bushing
                      • RaceMentally
                        • Nov 2013
                        • 137
                        There are brackets you can buy to do it. Usually we just grease them. We also slide leaf packs for and aft depending on how much pinion wrap we want. If dry slick I strongly recommend floating the rr and be smooth. There is nothing I enjoy more than watching a driver who has no comprehension of being a dry slick driver.
                        • RaceMentally
                          • Nov 2013
                          • 137
                          Originally posted by DANNY View Post
                          We can float then on the west coast and pretty much they all have em locked up. As Dave said it's too unpredictable lap to lap thus causing more trouble then helping. Most guys run the Chrysler leafs and "work" em but that's another deal all together. *WINK WINK* Find a guy that runs/ran them and is willing to teach you as it's better to see it then read it and you'll be unstoppable. JMO
                          Most guys have them floated (that know what theyre doing) Danny.
                          • dereksehi
                            • Jun 2013
                            • 307
                            Not everyone can float their leaf springs ie IMCA Northern Sportmod which is what i race
