spring question
  • medina41
    • Aug 2012
    • 12
    spring question
    So what are the pros and cons to swapping the rear springs to the heavier spring on rr and lighter spring to the lr any inputs much appreciated we run a 3/8 semi banked track
  • sidebite7
    • Feb 2013
    • 32
    you will decrease the dynamic wedge in the car, which will tighten corner entry and loosen corner exit. depending on you bar angles in the rear, you will be loosing traction
