Does anyone know how to tell the difference between a 79 and an 80 camaro. I bought a camaro stock and want to purchase new bushings.. they changed between 79/80. I have no Vin number to check and the body is no longer stock. Thanks any help would be appreciated.
Camaro Help?
What to watch for on the Camaro is the spindles and rotors. The changed at some point from SAE to Metric and are not interchangeable unless you have both...for example...you can not put a metric spindle w/ a SAE rotor, but you can use either spindle/rotor combo with the same upper or lower. At least this has been my experience.
