3100# Metric car, loose in and loose out
  • Driver50x
    • Jan 2013
    • 241
    Spring rates;LF 800. RF 700LR 250. RR 225. 180 pounds of bite. 52% left side. All stock suspension. It is pretty fast and fairly competitive, but is loose on corner entry, either on or off the gas. I am driving it pretty smoothly, not pitching it in. The problem is not the brakes. It is also a little loose on corner exit, but not real bad.Should I try stiffing the front springs 100 pounds? Or softening the rear springs a bit, or something else?
  • Dirt Knife
    • Jun 2012
    • 147
    Front springs
    Run a pair of 800's across front try that
    Or what do you have for stagger
    • Racer96m
      • 425
      How much rear %?
      Dave
      • Driver50x
        • Jan 2013
        • 241
        44% rear weight. That is the best I have been able to get so far under our strict rules.
        • DaveBauerSS6
          • Jun 2010
          • 566
          Put a 900 on the RF.
          Keep the 180 bite to start; thats close for the poor rear%.
          If possible add spacer to the RF if still loose.
          Is the rear end locked up or open ??
          Gator Engineering
          • Driver50x
            • Jan 2013
            • 241
            The rear end is locked.
            • speedbuggy
              • 259
              Your wheel weights are:
              LF - 840 RF - 896
              LR - 772 RR - 592
              I'd lower your bite down to 30lb or less and put LR-200, RR-175 springs in it.
              This should help you getting into the corner. You're only going to be able to get so much grip coming off with that light a rear weight.
              If you can move any weight, move it over to the right, too.
              • drtrkr244
                • Dec 2007
                • 1024
                It has been my experience, over the last 25 years, that stock clip cars like a 2-300 pound split across the front. I would first try a 900 on the LF.
                Also, metric cars have a high rear roll center and require more spring split. I generally have started with a 300 on the LR to offset the low rear weight %.
