need advice on corner entry
  • Nester Racing
    • Nov 2012
    • 23
    Hey guys I run a metric chassis and engine set back 13" with 600 lf 800 rf springs 250 lr 175 rr Car weighs 3000 lbs with 54.5 left 54.9 rear 50.5 cross 150 bite. Car is loose on entry and needs more forward bite what should I do stiffen front?
  • Fox_hunter42
    • 570
    without knowing more details, I think the front is way to soft. lf 900, rf 1100
    • drtrkr244
      • 1024
      Stiffen LF to 700/800 and RR to 200/225. That's too soft of a rr spring for a 3000lb car.
      • yenko1
        • Jul 2010
        • 18
        engine set back 13 ?
        • Nester Racing
          • Nov 2012
          • 23
          Yes engine is set back 13"
          • RACEMAN
            • 323
            13"? I don't think so. Looks to be 3-4". Not sure where you're measuring from but it's typically measured from a line that would pass through both spindles back to the frontmost spark plug.
            • Nester Racing
              • Nov 2012
              • 23
              It's 13" back from factory motor mount on frame
