Spring Question
  • emtb85
    • Feb 2013
    • 52
    Spring Question
    The track I run at has a real bad dip comming into one of the turns and when the car unloads it pushes real bad up the track. Can I incress the spring rate to help and if so what would be in the ball park range or is there anything else I could to to help the car. I run a 1000 on the right front on a 3400lbs monte carlo
  • Racer96m
    • 425
    To control the bounce, you need to look at shocks, not spring rates.
    Dave
    • emtb85
      • Feb 2013
      • 52
      What kind of shocks should i look for. I got easy ups on the front.
      • JustAddDirt
        • 1893
        that is the problem...shocks
        if you run an easy up shock, with a 1000# spring, the shock is not controlling rebound.
        your motion ratio of your lower a-arm is 25%
        so your right front spring that is a 1000#, at the ball joint is 250#
        if your easy up shock is say 100# of rebound, it is actually 25# with motion ratio figured in
        NOT near enough shock control
        you need something with more rebound control.
