What is a good Starting point on caster? LF 1 1/4 RF 3 3/4 is what i was told. Would both be positive camber or would the RF be negative and the LF be positive? Would you run more with power Steering. 3/8 mile medium bank track
Caster??
I would go more w/ power steering maybe 4.5 positive on rf 1.5 on lf remember more positive you have the harder it is to steer. It is mostly driver feel some like a lot of split to guide car into corner also the more positive the straighter the car will track on the straights .on camber rf 3.5 to 4 negative depending on camber curve on lf 1 to 2 postive you can learn a lot by having someone go outside the track and watch what rf is doing thru corner under load.Last edited by RW57; 10-04-2014, 08:32 AM.
Thanks. I cant get but plus 1 on the right side without tube a arm hitting over rail header. Whoever move tower moved them the wrong way. I got the left right right. Just cant get the right like i want it.
