Leaf spring mounting
  • HMS27
    • May 2011
    • 57
    Building a new clip car and installing leaf springs. What Is the purpose of making the front mounts narrower then the rear. I've seen them built both parallel and splayed so what's the deal?
    If your not racing on dirt it's your on asphalt!
  • HMS27
    • May 2011
    • 57
    113 people viewed and not a single reply. Must have everyone stumped on this one.
    • DaveBauerSS6
      • Jun 2010
      • 566
      Parallel will allow the springs to deflect more than toeing in. This can give the driver a false loose feel. Too a small degree, the deflection can add additional momentum in slipping the tire contact.
      Go easy on the coil guys.
      Gator Engineering
      • HMS27
        • May 2011
        • 57
        Thanks for the reply. So a small toe in of the front spring eyes would be a more ideal way to keep a more consistent feel?
        • Krooser
          • Nov 2012
          • 3117
          I've only run the springs parallel… my super stock is a leaf car and those springs are also parallel. Dave seems to be more familiar with the splayed deal… but those west coast guys are always ahead of the curve anywho...
          Class of 2019
          • HMS27
            • May 2011
            • 57
            Thanks for the reply. The last one I ran with leafs were parallel too. I read one sight that said the only reason they ever made the back wider on the Camero's were to allow room for a larger gas tank and the exhaust to fit inside the springs. Never said anything about an advantage.
            • DaveBauerSS6
              • Jun 2010
              • 566
              Actually the camaro was built parallel and the nova is toed. Ive ran both ways in a camaro and I prefer the toed. Read the afco tech on leaf springs, good info.
              Gator Engineering
              • HMS27
                • May 2011
                • 57
                Thanks, I'll check it out.
                • DaveBauerSS6
                  • Jun 2010
                  • 566
                  Cant find afco. Try this.
                  Landrum high travel and lightweight racing springs provide the consistent and reliable high performance you need to win. Check out the Landrum difference.
                  Gator Engineering
                  • HMS27
                    • May 2011
                    • 57
                    Thanks for you post. I plan on doing just the right side toed after doing some research. How much did you toe yours and did you build any lead into it or did you just square the rearend? Ive ran 4 link 3 link and both coils and leafs. I liked the simplicity and consistency of the leaf spring cars.
                    • HMS27
                      • May 2011
                      • 57
                      Ok, thanks for the input. I appreciate it.
                      • nguyenvinh2
                        • Oct 2014
                        • 98
                        ban nha quan 2 |nghiệp vụ bảo vệ | cty bảo vệ | chụp hình cưới trọn gói | chup hinh cuoi dep | vay cuoi | sua chua motor dien | sua chua may nen khi
                        • Camaro Guy
                          • Nov 2014
                          • 16
                          kind of old posts but I am mounting my leaf springs now and I think that the fronts need to be mounter closer (laterally) but which one should I move and how much? From what I can gather I should move the right side in but I don't want chassis bind either.
                          • DirtRacer9x
                            • Jul 2014
                            • 305
                            Mount RR parallel and LR towards center of car from stock location 12" on frame side. That's all I'm sayin.
                            • Camaro Guy
                              • Nov 2014
                              • 16
                              Move the front and the rear of the leaf spring in 12''?
