Was wondering if anyone has any experience with the two? In the process of building a street stock(81 monte carlo) and just had the lower A-arm and trailing arming done, but I have to put new bushing in them. I've heard good and bad things about both or them, rubber with flex alittle and throw off toe and camber. Afco steel bushings apparently require a lot of maintenance and can easily seize up. Just curious if anyone has anymore insight.
Also, is poly bushings an alternative 3rd option? Any advice is greatly appreciated.
