camaro help
  • grydergeyer26
    • Oct 2008
    • 168
    camaro help
    I have never ran a Camaro I was wondering if u put pinto spindles on it does it help running them and can u run swedge tubes in the front like a metric car or no
    what streering box do u recommend for the car what ratio it will be ran on dirt
  • Krooser
    • Nov 2012
    • 3117
    I have a Camaro stubbed dirt super stock. Can't help you with the Pinto spindles… we have to run GM stuff. But I have both swedge tubes and stock tie rods that came with this chassis… not sure what I'll be using.
    A good, inexpensive steering box to use is one from a '93-'98 Jeep Grand Cherokee. They are 12.7-1 ratio and bolt right on to most GM chassis. You can find rebuilts for under $100.00 (plus core) or used ones are usually about $40.00 in a salvage yard.
    The GM pitman arm will work but you'll need to convert your hoses to metric fittings or use small adaptors available from Lee Power Steering.
    Class of 2019
