I have a sbc 355 flat top, mild cam, 70cc 441 heads. I am thinking about switching to pump gas to cut cost. RF is $8.25 a gallon around here.....I have always ran RF in it ...What are the pro's and con's.... Thanks
Race fuel v Pump gas
On our spec head motors that are 64 cc.Made the same power on 110 as it did on 91/110 mix. Lost power on 87/110.If your fuel is 110 I would cut it 50/50 with 91.Back in the day we ran the 441 on 93 pump gas ,there was no margin for error.The first time we angle milled them it detonated and got a piston.
I would run aviation fuel its 100 octane and is substantially cheaper than race gas. I absolutely would not mix race fuel and pump gas as you will never get a consistent blend due to the leaded racing fuel being heavier than pump gas mixing fuel from an engine builders standpoint is asking for trouble.
I've been running av gas for 8 years and have several customers that run it and have never had any issue with detonation. Sure if you are running 11:1 or more compression I would use racing fuel but with the lower compression engines I've never had a single issue. There are different grades of av gas I use 100LL which is dyed blue.Last edited by dereksehi; 03-08-2015, 09:51 PM.
Actually Aviation gas is held to a much higher standard than other fuels, you just have to know what your getting. It has a lot of additives in it to prevent microbial growth and resist icing. The Blue 100/130LL is Low lead the 100/130 rating is 100 lean and 130 rich, its most commonly called 100LL. There is also Green which is a high lead content and also rated at 100/130, its the same as blue except for the lead content. There is also a Purple Avgas that is called 82UL, its basically low grade pump gas unleaded. Some confusion comes into play because back in the day Purple was the good stuff rated at 115, but they discontinued it because of low use and brought the color back for this 82UL crap.Originally posted by stock car driverAvgas is not 100 octane by the same standards as race or even pump fuel. That stuff is junk,
Dave2012 UMP Stock Car National Champions.
Yes Jeff, you know everything. I have worked in Aviation going on 30 yrs now, so this might be a subject that I have forgotten more about than you will ever know. Have a nice dayOriginally posted by stock car driverDave why don't you try helping people on here with some useful information instead of just trolling me? I had to unblock you just to confirm what I already knew. Your post wouldn't reference the original posters question in any way.
Were all on the www, we can all look up the colors and specifications for av gas.
Switched my 9:1 compression sport mod engine to 93 octane pump gas to cut costs last yr, and had no issues. Didn't notice any performance differences, and the plugs always looked great. Only thing I made sure of was to buy my fuel from a reputable gas station.
Its freaking AMAZING how bent you get, when a guy gets on here and trys to help others out. You absolutely are AMAZING Jeff.Originally posted by stock car driverWorking in aviation or if you know more about something than me, have nothing to do with the original posters question and neither have any of your replies... Your just a troll.
Av gas has a higher reid vapor pressure than pump gas.It is harder to vaporize it at sea level.BIG Headers
Barry Allen Racing Engines
Bret Kepner Photo's
Quote
I was not wanting aviation fuel. My compression is around 9.39:1... What would I have to do to convert to PG. Jets are 76 and 34 deg total timing. Thanks....
How do you end up at that compression? With a flat top piston or a dome piston?
If that is a flat top piston I would run it on 93 PG. add a gallon or 2 of R.F. to be safe and for the lead content to help lube the valves. If your jetting is on a 2bbl that's a little richer than I set them up.BIG Headers
Bret Kepner Photo's
