Camaro front spindles?
  • SRT17
    • 172
    Who makes replacement spindles? 70 - 78 Only ones I can find aftermarket are 2" drop....Cast # 371676 RH. Thanks...
  • oldgold
    • 207
    i think chevelle are the same
    • stock car driver
      • 3233
      lefthander had some years ago, same as full size impala. I cant imagine you cant find used ones those came on about every full size car..
      • stock car driver
        • 3233
        They are as cheap as 20 each here...
        http://car-part.com/cgi-bin/search.c...ey=&userPage=4
        • drtrkr244
          • 1024
          I read in one of the interchange books that 76-78 Cadillacs used the same spindle, only it was a lighter design.
          • SRT17
            • 172
            So all the mid 70's are the same ? When I looked up the cast number, only the Camaro comes up....I just thought that it would be better to get a new one. That you know for sure is good...
            • Krooser
              • Nov 2012
              • 3117
              New stuff is often cast instead of forged… not sure on those. 73-77 mid size GM is the same.
              Class of 2019
              • stock car driver
                • 3233
                actually no 73-77 are much much larger you don't want them they are geometrically the same but weigh several lbs more
                Camaro, 78 up to 88? impala,75-79 nova etc are all the same
                I ran Camaro for 10 years on pavement I only ever damaged one I would be happy with used
                • The deMORRILLizer
                  • Mar 2014
                  • 29
                  Originally posted by stock car driver View Post
                  actually no 73-77 are much much larger you don't want them they are geometrically the same but weigh several lbs more Camaro, 78 up to 88? impala,75-79 nova etc are all the same I ran Camaro for 10 years on pavement I only ever damaged one I would be happy with used
                  Camaro's switched to strut cars in 82. I believe 70-81 Camaro should all be the same 2nd gen spindles
                  • Driver50x
                    • Jan 2013
                    • 247
                    The 79-81 camaro spindle uses a larger inner wheel bearing and a different rotor, but is otherwise the same.
