Fast boy setup
  • Dirt newbie
    • Sep 2015
    • 1
    Fast boy setup
    just getting into racing and I'm wondering would the LR stacked spring from a fast boy setup work in my camaro without floating the RR my rule book says I can adjust perches for pinion angle but I'm not to sure if I can floatthe right side legally I'll have to take that up with the track but If it can be run on stock perch I'll stick with it.
  • dirtrace09
    • Aug 2007
    • 746
    You can redo the left side spring to allow for more arch and bite along with banding and unbanding the rear section of the spring. Most sanctions do not allow the rr to be floated.
    • chevy370lsx
      • Mar 2011
      • 50
      Haven't really looked at the bands that well but how are you rebanding them?
      • dirtrace09
        • Aug 2007
        • 746
        I used two flat pieces of strap and drilled holes in each end and used bolts to sandwich it down on the spring.
        • DaveBauerSS6
          • Jun 2010
          • 566
          And how tight are the bolts?
          Gator Engineering
          • dirtrace09
            • Aug 2007
            • 746
            Just tight enough to let the spring still move but not fan out.
