Any advice on arm bracket location. Installing 6 inch center tubular arms on metric chassis. Centered ball joint
A arm lacation advice
Use upper arm length for camber curve you want at that wheel. Mount upper control arm mount so that it is inline with lower control arm mount from a side view. use software or draw out on paper for the roll center you are looking for.set upper mount at these positions and weld her up. i have done this with stock mounts many times and you can not even tell anything has been changed. makes the car much more consistent!
