Pool bar spring rate
  • M2O8D
    • Jan 2009
    • 44
    Pull bar spring rate for 2800 pound three Link car? Open to suggestions.
  • JustAddDirt
    • 1893
    best would probably be a rubber biscuit bar. like a QuickCar bar
    • badfast47
      • 139
      I always used a 800lb. spring. I tried the biscuit bar and hated it, (no offense dirt.)
      It's just what i experienced. A progressive is suppose to be good also
      • M2O8D
        • Jan 2009
        • 44
        Got the call this winter to take over duties on this car this car carried the left front tire excessively last year just trying to find some ways to try to calm that down Took about a 50 pounds of bite out of the left rear which puts me at about 125 raise J bar on the Frame to try to eliminate some of the body roll Springs are left front 850 right front 1000 left rear 225 right rear 200 which seems to be pretty reasonable going to try it there
        • JustAddDirt
          • 1893
          how much left rear droop is in the car?
          What clip is on car? Metric, Chevelle, Impala, Camaro,Ford?
          • M2O8D
            • Jan 2009
            • 44
            Now has 5in drop never had a limiter before . Camaro stub
            • a25rjr
              • 3774
              That 200 is pretty soft for a 2800lb car. I would stiffen it up to a 225 and raise the jbar on the pinion. By putting more angle in it, ur increasing body roll by planting the rearend more.
              Turn LEFT, Vote RIGHT!
              • JustAddDirt
                • 1893
                agree 100% with above post.
                might try a bigger tie down LF shock as well
