Hello all I have a 04 cavalier 2.2 5speed I have been playing with weight and was looking for some input on what percentage of weight would be ideal. I had it at 70/30 front/rear but the car was way to loose when entering the turn and wanted to come around on the turn therefore causing me to scrub a lot of speed. Have any of you played with weight? if so what worked for you guys? Thanks in advance
cavalier weight distribution
try keeping the weight on the left,right in front of or even with the left rear,dont weight behind the rear end
handling
Sound like theres to much cross weight LF to RR Start reversing cross weight till it doesn't want to come around on you.Originally posted by will34 View PostHello all I have a 04 cavalier 2.2 5speed I have been playing with weight and was looking for some input on what percentage of weight would be ideal. I had it at 70/30 front/rear but the car was way to loose when entering the turn and wanted to come around on the turn therefore causing me to scrub a lot of speed. Have any of you played with weight? if so what worked for you guys? Thanks in advance
the rear is just the same as a trailer behind a truck, its just being drug around
if you let off the gas to fast or too much the front tires are BRAKING while the rear are just trying to pass you buy just like a trailer would behind a truck on a curve if the truck slammed on the brakes
you don't need to add weight to the rear to stop that
if your turning your front wheels too sharp that also is like braking
Do you have power steering?
