Does anyone have a cheat sheet with set up for pro four at Carolina speedway. I'm running a mustang 2.3. I'm looking for rear gear, springs, camber caster and tire pressure and sizes. Any info would help. I used to run stock 8 now I'm getting back in the easy way!!! Thanks in advance.
Set up for Carolina speedway
Ok here is what I have come up with. I hope this helps someone as no one could provide this info. Dirt track only. Base set upWeight: 52% left 45% rear or as much as possible cross 47%Springs: LF:600 RF:650 to 700 LR:150 RR:125Camber: LF + 1.5. RF -6. Caster: LF:+2.5 RF: +3Tire pressure: wet to tacky: LF-14-16 RF-18-20 LR-14-16. RR-18-20 Dry/slick: LF-10. RF-14 LR-10. RR-12Stagger: wet 2-2.5 front and rear Dry 2-3 front .5-1 rearThis is just a base set up. You will need to calculate your turns and figure your gears for the track you are running. If anyone wants to add or tell me I'm wrong please feel free to do so. Good luck this season.
