Another oil pressure question
  • FLYIN-9
    • May 2015
    • 83
    ok, I've got an electric drill on the oil pump shaft. Shoul oil be gushing out of thst hole? It's doing that with less than 20 lbs showing on the gauge. Thanks F-9
  • Browndog
    • Feb 2009
    • 89
    What is a thst hole?
    • FLYIN-9
      • May 2015
      • 83
      Oops, distributor
      • Browndog
        • Feb 2009
        • 89
        Why do you have 2 threads going for the same problem? As I understand you bought the engine used. Did you have the pan off? What prompted you to check the oil pressure, was there a previous problem?
        • car62
          • 1579
          yes oil will come gushing out,slow down the drill speed,all you are doing is priming the engine,just make sure you are going clockwise
          www.raceidaho.com
