Shim oil pump
  • FLYIN-9
    • May 2015
    • 83
    Shim oil pump
    I've heard of people placing washers between the oil pump & pick up tube. Is there some "rule of thumb as to how much is needed for an increase in pressure? F-9
  • Browndog
    • Feb 2009
    • 89
    You want to restrict the flow?
    • FLYIN-9
      • May 2015
      • 83
      just would be more comfortable with a little more pressure. Everything is new, but set up a little loose.
      • Browndog
        • Feb 2009
        • 89
        restricting the flow on the suction side is not going to give you more pressure. If the engine is new why is it loose?
        • Jb35
          • Jan 2013
          • 37
          I don't think you would want a washer between oil pump and pickup. However there is a spring inside the pump that a lot of people,including myself, use a washer to shim up and add more pressure. An 1/8th inch thick washer should do.
          • car62
            • 1579
            Definitely don't want washers between tube and pump,it will suck air...if you want more pressure,go with a Melling M127
            www.raceidaho.com
            • FLYIN-9
              • May 2015
              • 83
              I did put the washer at the spring inside the pump & seemed to help. thanks to all for your input!!! I still might look into the melling pump too.
