Anyone running this distributor on the 2.3 ford? I'm turning right at 7500 put it seems to have a ignition flutter at the upper end of the RPM range. I've got a TFI with the v8 module to put back in but not sure how to wire it up to my MSD box. I looked at the diagram on Power by Race, but that seemed to be for the older EFI.
Pro Comp Distributor
On TFI the white wire from MSD box(crank trigger)gets hooked to green wire on TFINo matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
