2.3 ford flywheel bolts breaking
  • grydergeyer26
    • Oct 2008
    • 168
    Somebody explain y I keep breaking flywheel bolts I torque them down to stock specs
    they r diggin in to flywheel and making hole out of round
    to add I broke two sets of arp bolts with 22r I didn't but them on so
  • 84Dave
    • 915
    Common problem on a 180-degree crank 2.0/2.3L Ford, with even moderate performance upgrades. And the problem gets worse with a higher numerical rod-length to stroke ratio. Drill the flywheel & install a 7/16" dowel in the crank flange. Problem solved! -Dave-
    • Milford Motorsports
      • Jun 2008
      • 285
      I always use a steel flywheel saver on the aluminum flywheels.Keeps bolts from digging into flywheel and loosening up.Always lock tite flywheel bolts also.
      • grydergeyer26
        • Oct 2008
        • 168
        Stock motor that's part I don't get
        explain dowel
        • Dirtman29
          • 1690
          What type of flywheel, the OEM mustang bolts are too long to use with anything other than the mustang OEM flywheel. I have used the escort flywheel and currently have an alum flywheel, both required shorter bolts, only around 1/4 to 3/8" shorter but the long (stock) bolts will bottom out in the crank, you will think theyre tight but they arent!
          • car62
            • 1579
            could also be junk in the bolt holes(dried up loctite,dirt,etc)preventing the bolts from seating all the way,it only takes 1 or 2 loose bolts to cause problems.
            www.raceidaho.com
              • Jun 2008
              • 285
              Have you tried a different flywheel.Are all three pressure plate locating pins in place.Check for broken spring in pressure plate,and clutch plate.Also make sure crank pulley is not bent or loose.If you happen to have a lightened stock flywheel,check it for cracks.Had a customer felt a slight vibration while racing,the flywheel had developed several radial cracks from the center hole and had begun to egg shape.probably was seconds from catastrophic failure.I have several NEW stock flywheels for sale if anyone is in need.
              • grydergeyer26
                • Oct 2008
                • 168
                First time broke was a 88 ranger flywheel, bolts
                then used 10000 rpm and they backed out of crank
                last time it broke used pinto flywheel which I used forever on that motor
                could tranny have something to do with it
                  • Jun 2008
                  • 285
                  Can't imagine how trans would cause this problem.Think I would look inside motor,possible cracked or bent crank,damaged piston or rod.Worst case you replace bearings and rings have a freshened engine and know there are no problems internally.
                  • boportt
                    • Aug 2007
                    • 190
                    2 guys got it rite them bolts is to long u need shortr bolts cuz stock bolts are too long for alum flyweels and escort weels.
                    • grydergeyer26
                      • Oct 2008
                      • 168
                      Using a stock flywheel when broke so I need shorter bolts 4 that too didn't know that
                      • boportt
                        • Aug 2007
                        • 190
                        u didnt say u got a stock wheel so everyone is guessing and now aint one person f0cking rite maybe u got a bad torq rench is it a stock mustang wheel escort or pinto? cuz stock mustang is thicker than pinto and scort
                        • checkeredflag2006
                          • Jan 2009
                          • 212
                          you (not a nice word)(not a nice word)(not a nice word)(not a nice word) do you read like you spell? read the post before you type your smartass remarks!!!!!!!!!!!
                          • grydergeyer26
                            • Oct 2008
                            • 168
                            pobort i said a 88 ranger flywheel and pinto flywheel i said were stock used two different torque wrenches so thats not problem can it be nose cone in tranny
                            and thanks everyone 4 ideas
