fan blade drag and fuel pump drag?
  • dmstang
    • Jan 2010
    • 31
    Currently I'm using 6 blade flex fan and I'm thinking it's too much of a drag on the engine. I believe rules allow electric fan, would it make any difference if I used electric fan?
    I also use stock fuel pump and the rules allow electric pump, would it also make any difference if I switch to electric fuel pump?
    I would like to get the most out of my engine and I don't have any access to dyno so it's all guess work here.
    Thanks for your help
  • longhornracer
    • 220
    fuel pump wont make any diff in power. I have always ran a flex fan myself but the more weight you get off that motor the more power you get even if it is minimal
    • drtlvr
      • Feb 2010
      • 233
      I've ran electric pump and fan and switched to a nylon fan and mechanical pump. I can't tell a difference, just cheaper!
      • 84Dave
        • 915
        At 100% efficiency, 746 WATTS = 1 HP. P(watts) = I(amps) x E(volts). Our 6-blade, 16" electric fan @ the back of the radiator pulls 11 amps running full blast. Our alternator output is 14 volts. So...... P=IE is 154 WATTS to run the fan. And 154/746 = .206 HP to run the fan. Most electric fuel pumps require 4-5 amps to run 'em. That equates to slightly less than .1 HP to spin the fuel pump. A 4-stage dry-sump oil pump requires right at 2 HP to turn it @ max rpm. A wet-sump oil pump, much less. It requires MUCH more HP to spin the tranny/rear-end than all the above combined! -Dave-
        • rtcaldwell
          • Jan 2009
          • 60
          Any Nylon fan will work or is the water pump some oddball bolt pattern?
