Ford 2.3 motor, stock bottom end, built head, running at about 7200rpm. Motor ran great for about the first 8 laps. Then on the last 4 laps, starting missing when I got into the 6500 & higher rpm range. Lower rpm range motor ran fine. Engine did diesel a bit when I shut it off. Tried checking the timing and everything looks lined up. Put in a new coil and ignition module and still have problem. Pulled spark plugs and they were all "paper sack brown" in color. Anybody have any other ideas?
2.3 Miss
If you have the plugs gapped @ ~.040", pull the gap back to .030" and try it. With the engine warm, shut it down and immediately remove the bowl sight-plug on the Holley. The fuel level should be about 1/16" below the threads in the sight-plug. Replace the o-ring on the needle-seat assembly of the Holley. If it's old & worn, fuel pressure can blow fuel by the needle-seat and 'flood' the engine. Fuel pressure 5# or less? 'Run On' @ engine shut-down? Sounds as though the throttle blades have too much of the fuel-transfer slot exposed @ idle. I.E. the blades are to far open @ idle. That can cause major problems when you get out of the throttle into a corner. The high vacuum can pull excessive fuel out of the transfer slot & flood the engine. The engine will 'sag' out of the corner, and as it begins to 'clear' at elevated rpm, and if the AFR is about 10.5:1, you can experience a high rpm 'rich miss'. Particularly if the ignition may be running out of 'reserve' @ higher rpm. Other than the above..... the engine should run fine! -Dave-
