fox body help
  • grydergeyer26
    • Oct 2008
    • 168
    fox body help
    building a car from scratch never ran a car always trucks
    what spring rates do i need to start with
    Struts do i get one 5.0 or tbird for right front heard rumors of both
    semi banked 3/8 track dirt not clay
  • Dirtman29
    • 1690
    Springs: RR 150 LR 200 RF 750 LF I use OEM cut to height needed
    Shocks: rear, napa part #94079
    Struts: LF OEM 4 cyl. RF OEM mustang GT 5.0 strut.
    Get a RF LCA from an 87-88 Tbird its a direct bolt on part.
    This is exactly what I run on mine and it handles great, high or low line, dont matter.
    • crcltrakr
      • 293
      If you haven't put cage in yet, stitch weld a piece of 2" box tube on top of the rocker box, from wheel well to wheel well, then weld cage posts and downtubes to this. Way better than welding plates to floor pan, if rules allow.
      JerryM
      • millerlt3
        • 96
        I run LF oem 4 cyl Replacement strut and a 600 lbs on the RF a 70/30 drag strut for the 5.0 fox body mustang and a 650lbs on the LR i run 150 lbs and a 125 lbs on RR with carerra 50/50 shocks on both
        Miller
        • pilotracer
          • 160
          read
          lf 500-650 rf 650 to 750 rr 100 to 150 lr 175 to 250 i would go with monroe blue struts and yellow shocks work really good pretty much what dirtman said to a T
          • crazyhorse
            • 430
            i have a lca from a 87-88 t-bird if anyone needs one.
            • grydergeyer26
              • Oct 2008
              • 168
              How do u guys hold your racing springs in
              • boportt
                • Aug 2007
                • 190
                u gotta run penske or qa-1 anything else is junk go coil over and u aint gotta worry about springs falling out.. 750# on the front??? on dirt must like plowin the dirt.
                • grydergeyer26
                  • Oct 2008
                  • 168
                  Coilovers can't have
                  were do u guys get gears for rear end at
                  • boportt
                    • Aug 2007
                    • 190
                    u get gears at teh junkyard thares bout 7-8 ratios u can get
