i have a 3tc needing to get a few more rpms out of it. will advancing the timing let it turn a little more or retarding it let it turn a little more. what is the best cam timing on the gear to run and what timing at the distributor?
3tc rpm and timing question.
should have phrased that better. i have plenty of power down the starights and on top end. could usea a little off the corner. what im asking is will advancing the timing let it turn more rpms i run out of gear about 75 to 100 feet before i need to really not enough to change the gear. i ran about 8400 rpms last year. i messed with cam timing and ignition timing over the winter and now it only turns abou 7700 at most. if i can get tha rpom im losing back i would be perfect.
