i just bought a 94 escort flywheel for a 1.9l. i plan on using the mustang clutch and pressure plate, the tranny is a mid 80's 4 speed. What do i need to make everything work.
escort flywheel help
Do NOT use the stock Mustang flywheel to crank bolts!!!
They will appear to torque up properly, but the shoulder contacts the crank before they truly tighten up on the flywheel. It will end up coming loose, and probably breaking the bolts
Get the bolts from the Escort, new if at all possible. '91 - '96 1.9L are all the same.
Also I had to get my Escort Flywheel bolts from a Ford dealer. I could not get them from a parts store.Originally posted by jatchis View PostDo NOT use the stock Mustang flywheel to crank bolts!!!
Man I wish I had known about that place 2 years ago, I paid like 40 bucks or something like that for them from the dealer.Originally posted by jatchis View Post
