Will it fit?!
  • hornetracr99
    • Apr 2010
    • 41
    Will it fit?!
    is it possible to put an escort engine in a plymouth laser?
  • boportt
    • Aug 2007
    • 190
    shur i no a pinto moter fits in an escort anda neon moter fits in an omni anda buick nailhead fits in a 51ford anda 289 fits ina pinto so if u is smart enuf u can maker fit
    • Headhunter
      • 1338
      Seen a big block chevy in a MG Miget and a bbc in a Opel manta also.
      • Foghorn
        • 293
        But why would you?
        • Dirtman29
          • 1690
          It may fit, but good luck hooking ANYTHING up, Im sure CV shafts are totally different in spline and lengths, and all the wiring harness connections as well. Be cheaper and much easier to buy another car.
          • return to dirt
            • 1008
            did the escort with the 2.0 pinto engine use a diesel transaxle? the ONLY person i have ever seen post on here about the 2.0pinto/escort combo is dodge22. do you have a secret id boportt?
            olin
            • boportt
              • Aug 2007
              • 190
              thare is a guy that ran out hear that did it idk what tranny he used a 2300 w. a pinto pan prolly cuz the front sump wuld make more sence turning left wuld put all the oil in the rite spot.
              • Irace93
                • Feb 2010
                • 54
                Use your head and out a 2.0 seabring motor in it! then its manufacture correct!
                I know you can stuff a Modern neon/Eclipse/seabring 2.0 in them! takes some time and fab work!
