neon set up help?
  • steveshawjr
    • Jan 2008
    • 430
    some people think because the tire size say p205/75/15 is the same as a p205/75/14 and in fact there not lets brake this down on how a tire is measured
    p205-width of tread in mm
    75- height of sidewall by % of tread width
    now lets do some math
    14 inch wheel = 2 * 3.14 * 7 = 43.96 circumference
    15 inch wheel = 2 * 3.14 * 7.5 = 47.1 circumference
    205 is close to 8 inch so we will use 8
    75 / 100 * 8 = 6 the height of the sidewall in inch
    now lets make it a circumference of a tire
    6 * 2 + 14 = 26 / 2 = 13
    2 x 3.14 x 13 = 81.64
    81.64 is the circumference of a tire for a 14 " wheel
    6 * 2 + 15 = 27 / 2 = 13.5
    2 x 3.14 x 13.5 = 87.48
    87.45 is the circumference of a tire for a 15 " wheel
    its a big difference when its roughly 100 rpm difference per inch of tire
    looking at almost 600 rpm difference between a 205/75 14 and a 205/75 15
    just some food for thought when it comes to tires
    62 mini mod
    • little302
      • Jun 2009
      • 94
      After all the discussion
      This mans 1st question hasnt been answered. It was about set up...IF I had any knowledge of such, Id help. My suggestion is to PM 22 Dodge. Hes full of it!! It being any amount of useless, and critical info that you may need...
      • Breelee01
        • Aug 2016
        • 1
        Hello so I'm running a dodge neon 1997 dohc at upper Iowa speedway on dirt. And needing some help with being faster in the corners. I run third gear with 14" tires. I have good camber but not fast enough on the starts and in the corners.
        • bgreorasmaarleya7044
          • Mar 2017
          • 1
          neon set up help
          Hi guys,I was wondering how you can measure and set the mk147 kit at exactly 50 Hz. I would like to put it fixed at that frequency.Is there somebody who can tell me?Many thanks in advance.sander13
          http://do-kompa.pl/
