Oil pressure
  • Goin2Texas
    • 43
    Oil pressure
    Never had this happen before and it scared the %^&#@ out me.
    2300 Ford. Last race out it sheared teeth off the aux shaft and distributor. Cleaned EVERYTHING out, conventional 10-40 oil, new Fram filter, new pump (std Melling - no high volume or high pressure) and pickup, etc. Went to start it tonight, and as soon as it fired, oil pressure gauge pegged and it blew the o-ring/seal on the filter - oil everywhere!
    What happened? and what should I look for?
    I didn't say it was your fault - I just said I was blaming you.
  • car62
    • 1579
    check to see if by chance there are 2 o-rings between the filter and block
    www.raceidaho.com
    • boportt
      • Aug 2007
      • 190
      2 orings on filter aint gonna couse pegged gage so u gotta prob w. the pump releif valve.
      • Headhunter
        • 1338
        yes somthing is in the pump RV.. I had one with a yellow o-ring in it. no idea where it came from but 100+ psi of oil pressure did the motor no good.
        • raceman17
          • Jun 2010
          • 68
          Im not familiar with the 2300 motors or what filters are avaliable but do yourself a favor and get rid of the fram filter. If you can use a racing filter. I lost a motor using a regular filter. High oil pressure blew the guts outof the inside of the filter and restrited the flow of oil to the bearings.
          • boportt
            • Aug 2007
            • 190
            it aint the filter cuz the preshure releif valve would dump off before blowin out the filter oring. i run frams and aint never had no problems ever
            • 84Dave
              • 915
              All the above is a good reason to ALWAYS pre-prime the oil system with an electric drill/pump drive before starting the engine subsequent to any failure/repair. The pressure problem would likely have been observed with the drill turning the pump. -Dave-
              • Goin2Texas
                • 43
                I did prime it with a drill beforehand and it pumped the oil all up to the head, but I guess I didn't pay enough attention to the gauge? Maybe I didn't 'prime' it long enough or fast enough?
