I am running Nissan rear wheel drives. There is very little info out there to show what the various gear ratios are in the trans. Can anyone give me a heads up on how to try and figure out what i have? I have four diff trans. I have heard in the past that you turn the input so many times and count the output or something. Anyone?
How do I check tranny ratios?
relay help with some more info on what the trans came out of do you know how many Nissan's there are out there also stick or auto lol62 mini mod
i think the ratios are the same as they used in the trucks. i have it at home. i'll see if i can find it and post them for you.
olin
there were a couple ratios used.
88-95 2wd trans for the z24 and ka24;
1st 3.32
2nd 1.90
3rd 1.31
the 4sp trans had the same ratios as the 2wd 5sp except for no 5th. the 4sp is also lighter then the 5sp.
4x4 trans for the z24 and ka24;
1st 3.59 or 3.99
2nd 2.25 both
3rd 1.42 both
this is for the fs5w71c 5sp and the f4w71c 4sp.
hope this helps.
olin
Stock KA, SR & CA Transmission and Rear Diff Ratio's
All KA's SOHC and DOHC
1st = 3.321
2nd= 1.902
3rd = 1.308
4th = 1.000 (Direct Drive)
5th = 0.759 (Over Drive)
All S13 SR20DET's
1st = 3.321
2nd= 1.902
3rd = 1.308
All S14 SR20DET's
1st = 3.321
2nd= 1.902
3rd = 1.308
5th = 0.838 (Over Drive)
All JDM CA18DET's
1st = 3.321
2nd= 1.902
3rd = 1.308
All Euro CA18DET's
1st = 3.592
2nd= 2.057
3rd = 1.361
5th = 0.821 (Over Drive)
KA24 4WD Trucks (Hardbody's/Frontiers)
1st = 3.985
2nd = 2.246
3rd = 1.415
Note: All the Transmissions Listed are FS5W71C Transmissions.
- The Z31 300ZX also uses the FS5W71C Trans but it has the Same Specs as the KA Trans so don't worry about it.
ALL 240SX FD's are 4.083
S14 SR20DET FD's: Taken from the FSM
M/T = 3.692 (48/13)
A/T = 3.916 (47/12)
S15 SR20DET FD's:
M/T = 3.692 (HLSD)
A/T = 3.916 (VLSD - Same as S14)
