anyone have experiance with this problem and possible solutions? We're fighting this since day one of the season. Thrown about everything at it from one extreme to another. The only handling characteristic that changes with any chassis change is push off the corner. car always turns in fine but breaks loose bad mid corner. this is asphalt track.
to try and reduce this sudden and immediate spin, I've tried spring rates on the rear from 200# to 600# no difference, front spring rates from 300# to 550# no change removed front sway bar to running it with a lot of preload, no difference for snap loose but with load on bar, it pushes out so bad, I couldn't get on the gas at all. I've added 100# weight to the back of the car. with weight on LR car would still snap around and then push off. with the weight on the RR car snapped around and actually pulled hard right down the straights. Put 50
# on left front behind back bumper and no improvement on the snap loose but it did have better pull off the corner.
I verified there is nothing binding in the suspension nor any loose parts or worn bushings.
i searched for days on the net and all I find is a bunch of forums where guys talk smack about all driver error.
Any ideas on snap loose issues/resolution
