Mustang Rear End fits...?
  • Double W Racin'
    • Jul 2011
    • 35
    I am looking at building a '91 Mustang 5.0 Gt. The rear end's upper control arms are located in a different position than the earlier Fox Bodies. Has anyone grafted in an earlier rear end? The reason for this swap is to change gearing.
    Caution: I spin without warning.
  • bushracing67
    • Oct 2007
    • 904
    um, no they arent.. they shouldnt be anyway.... i would go with a 5 lug conversion using sn95 suspension, if not get a rear out of a turbo couple with an auto, 4 lug 3.73 disc brake
    • car62
      • 1579
      79-93 are all same location.
      www.raceidaho.com
      • spddmn
        • 199
        Thats what I thought. Sounds like he has a 8.8 from a gt and trying to put a 7.5 in. I know the gts had more gadgets hooked to them.
        • boportt
          • Aug 2007
          • 190
          them gt's and svos and turbo tbirds and turbo cougars had quad shock thats it. wtf do you need to take out a 8.8 for a 7.5? purty much same gears avail in both.
          • Double W Racin'
            • Jul 2011
            • 35
            You are correct sir.
            The '91 8.8 GT's has upper control arms that go backwards from a bracket, located on the outer tubes, above the lower control arm bracket. The earlier model 7.5" has upper control arms that are located above the pumpkin and go forward up to the chassis.
            The reason that I'm going to a 7.5" from my 8.8" is to change gearing and the fact that I have access to the 7.5 in the proper gear. I do not have access to the 8.8 in the correct gear with out paying a boat load and have to ship it here.
            • boportt
              • Aug 2007
              • 190
              dude them aint uper contol arms them is quad shocks.
              • Double W Racin'
                • Jul 2011
                • 35
                Hmmmm.... Maybe I need to poke my head under there a bit further. I looked at it from the rear and could not see the Upper Control Arms from my angle and assumed that those were different from what I was used to seeing.
                This is my first forray into building a Mustang. Thanks for the help. A million questions yet to come.... Stay Tuned...
                • boportt
                  • Aug 2007
                  • 190
                  spose its purty hard to get ur head up thare sinse its so far up ur butt
                  • Double W Racin'
                    • Jul 2011
                    • 35
                    You're NOT the first one to bring that to my attention.
                    • spddmn
                      • 199
                      Funny if you click on the orange box next to boport it says( boport has little shameless behavior in the past)
                      • boportt
                        • Aug 2007
                        • 190
                        ya so and u r a dumb$hit.
                        • car62
                          • 1579
                          what gears do you need in the 8.8...i have access to every ratio ring and pinion between 3.08 and 4.10 that ford makes
                          www.raceidaho.com
                          • Double W Racin'
                            • Jul 2011
                            • 35
                            I'm looking for the 3.08s. However, I have never setup or changed the gears out. Would prefer just to swap out the rearend.
                            • boportt
                              • Aug 2007
                              • 190
                              y do u wanna 308 in a 5.0 mudstang? ud never get into overdrive until u hit like 100mph. and she'd be real doggy off the line. that lil 7.5 rear prolly wont last long if u pound her.
