Gearing help
  • 47 racing
    • 21
    Gearing help
    1/2 mile track medium banking 2700 bottom end aluminum d port head Holley 500 carb efi intake turn 8100 on 3/8 mile track normally but looking to travel what final drive ratio do you 1/2 mile guys run I'm running. 699 with 2:14 second gear and 327 rear gear
  • steveshawjr
    • Jan 2008
    • 430
    2.73 with a 5 speed should be close
    62 mini mod
    • steveshawjr
      • Jan 2008
      • 430
      the 2.34 second 5 speed
      62 mini mod
      • boportt
        • Aug 2007
        • 190
        dont change tranys, usea 273 w. ur 2nd gives u a 584final or go 373 and run 3rd for a530 final or getta 410 r&p from an arrowstar run 3rd give u a 582 final
        • steveshawjr
          • Jan 2008
          • 430
          on our teams enduro mustang we run the 214 2.73 deal and only turn about 6500 rpm at the most but its a tighter 1/2 pavement and there 200lap races
          so i guess it depends on the track and how many rpm you want to turn
          62 mini mod
          • 84Dave
            • 915
            A rough estimate in general. For every .1 change, up or down, in the final ratio to the pavement, the engine rpm will respectively decrease or increase 125-150 rpm. -Dave-
            • 47 racing
              • 21
              Better to use the 273 second gear combo or the 410 3rd gear I have access to both ratios
              • boportt
                • Aug 2007
                • 190
                i run 1/2 mile w. 536 final and spin 7800
