Ford 8"
  • Rtruck
    • 123
    Ford 8"
    Can't find my old notes on the following:
    Need fluid capacity of rear end-8"
    Torque specs on pumpkin-8"
    Fluid capacity of 7.5" diff.
    Thanks,
  • pobort
    • 421
    fill it until the oil is to the bottom of the fill hole. about 2qts
    • dave41
      • 208
      oil
      street 2 qt's oval racing 3 qt's
      • pobort
        • 421
        i'd run 4 quarts just to be safer
        • car62
          • 1579
          i use about 1.25 quarts in the 7.5...8" im really not sure about.
          www.raceidaho.com
          • r3tracing
            • Jul 2011
            • 224
            which is it pobort 2 or 4
            • Foghorn
              • 293
              Fill it to the original Ford level with a good quality oil and it's good.
              • ATOYOTA
                • Dec 2010
                • 57
                Idk if it was me, i'd buy some gear lube and fill until it was at the bottom of the fill hole. If i came up short i'd buy more if i bought too much i'd put the left overs on the shelf so i'd have it on hand.
                • Rtruck
                  • 123
                  Thanks guys...appreciate the help....3 for racing sounds right.
                  • Old Rob
                    • 1027
                    If you donot have the rear end modified to keep all the oil in the center during hard cornering, then overfill it at a minimum of 1/2 quart. We modify all of our housings to keep the oil in the center.
                    • steveshawjr
                      • Jan 2008
                      • 430
                      i use good old 20/50 oil in mine fill it till she poor out and than add a touch more. change it at half way through the season no problems same gears 4 years.
                      62 mini mod
