Anyone running e85?
  • ATOYOTA
    • Dec 2010
    • 57
    Anyone running e85?
    Thinking of switching but getting a lot of info that's all over the board on what to do.
  • bodontknowdiddly
    • 83
    we use PEX tubing for fuel line tank to carb, put in jets 8-10 sizes bigger, use a 5.5-6.5 power valve. Yall may have to drill power vavle restrictors.
    • Milford Motorsports
      • Jun 2008
      • 285
      Pex? I have seen air hose,plastic hose,copper tubing,hydraulic hose used as fuel line.Just can't believe anyone would be so foolish as to take a chance on getting burned up just to save a couple bucks.Fuel line should be one of the first things teched at any track!
      • pobort
        • 421
        how do you figure. i too have seen guys running pex. cross-linked polyethylene,fuel cells are made form polyethylene
        PEX is also used for natural gas and offshore oil applications, chemical transportation
          • Jun 2008
          • 285
          Fuel cells may be made from polyethelyne,but around here ALL the tracks require they be contained in a STEEL can.Anything less than a steel or braided line run under the car is just asking for trouble.
          • pobort
            • 421
            so you've never seen the OEM fuel lines on say an efi ford???? (polyethelyne from tank to injector rail).
            • steveshawjr
              • Jan 2008
              • 430
              we bought a mettering block from quick fules al ready preped ofr e85 they told us 8 -10 on jets same powervalve 28-31 squirter.
              i must say right out of the box they where within 2 jet sizes and o noticed a huge power and torque gain.
              also we run a inline electric fuel pump that pumps from 5-9 psi on demand havent had an issue at all
              62 mini mod
              • ATOYOTA
                • Dec 2010
                • 57
                I must say right out of the box they where within 2 jet sizes and o noticed a huge power and torque gain.
                Also we run a inline electric fuel pump that pumps from 5-9 psi on demand havent had an issue at all
                thanks for that info. I checked their web and don't see a kit for a 500 problem i see in their stuff is all the holes on the back of the metering block we cant have carb stuff that's been modified like that. How much did you pay for your block you wouldnt by chance have the part number from them?
                • steveshawjr
                  • Jan 2008
                  • 430
                  you have to by them in pairs ive seen some sites that offer them in singels there 130 for the pair
                  http://www.quickfueltechnology.com/m...k-kit-e85.html
                  im sure if you contact them they could tune your curent metering block or make a stock apreering one for you they a grate help and gave me all the info needed to make there stuff work on my 350
                  62 mini mod
                  • ATOYOTA
                    • Dec 2010
                    • 57
                    Thanks a lot of the info. Great to see that some people have been successful with this without all the hype and drama.
                    • steveshawjr
                      • Jan 2008
                      • 430
                      heres a vid of my last win this past weekend Toyota power and torque is up big time and rpm went up a ton as well
                      the smoke is from when number 1 plug wire broke off the end of the sparkplug and was just barley sitting there on.
                      62 mini mod
                      • ATOYOTA
                        • Dec 2010
                        • 57
                        Looks good nice racing. What are you using for fuel line? I'm really thinking that the pex idea will work. I checked out a bunch of mods that are running e-85 and quite a few are running pex for fuel lines.
                        • steveshawjr
                          • Jan 2008
                          • 430
                          Im just running some relay good high grade injector rubber line have not noticed any of it coming apart as of yet anyways. it will be one thing i looking at come down season.
                          im not one for steel or plastic lines my self Ive seen em crack under the stress of the vibrations caused by such high rpms we turn in Motor sports.
                          ive done some looking on Google and found if you use a good grade rubber fuel line with a silicone layer inside the hose is e85 safe
                          62 mini mod
                          • ATOYOTA
                            • Dec 2010
                            • 57
                            I have never ever seen plastic lines fail on anything yet. I sure have seen a lot of rubber lines fail. I bought a used race car and it had all rubber inside conduit running thru the interior. I hate that idea. When I pulled out the fuel line the conduit was full of gas and the line was cracking. That setup sure seems a lot more dangerous than a flexible plastic line. you can take PEX and kink it over and over again and it doesn't crack. I use to install hydronic heating systems so I'm pretty versed in it's application for hot water systems. That material is darn near bullet proof. Easily withstands high pressure, temp changes.
                            • that dude
                              • Jul 2010
                              • 75
                              I run aluminum 3/8" OD line for my fuel line, under the car instead of through the car.
                              A product similar to this..
                              http://www.jegs.com/p/Earls/Earls-An...74866/10002/-1
                              One of my brackets vibrated loose, and the fuel line was dragging a little and the car bottomed out on it once on the trailer. It just mashed the tubing flat so fuel woudn't flow, but it beat ripping a whole in some softer material like rubber, which would have leaked everywhere.
