has anyone ever tried to mount a krc power steering punp to a 2.3 and if so how did you do it or what bracket did you use
2.3 power steering
i mounted ours on a 1 1/2" peice of angle iron mounted to the 2 holes on the left front side of the block,then used a chevy aluminum block mount between the pump and the angle. be sure to lign up pulleys before marking holes in angle for the block.if needed i can get pics for ya.but it was a simple and clean mount.hope this helps
if you could send a pic to r3tracing@yahoo.com that would be a big help. we have a small block mount and pump so that is exactly what we are trying to do. thank you very much ray.
Could u send pics to kelracing33@gmail.com, recived the same pump in a local trade no clue where to start
