i was needing to help a buddy of mine with his mini stock..what would be a good start on springs and shocks and weight percentages and tire pressures??? running hoosier rc 4...and stagger??and there is no wedge bolts so how tall of springs would u run on all 4 corners?? thanx
87 Mustang? setups,springs
What kind of surface? What is the ride height rule? or better yet what track? You really need to be more specific when your looking for this kind of information. actually a link to the rules would be good too.
well i just need a basic spring and weight percentages for this mini stock..track is a dirt track 3/8 mile banked...dont know ride heights im tryin to get info...i dont know much about these cars i just deal with late models....u can run racing shocks...
News
Photos
Events
Points
School
Track Info Track Facts
Directions
Rules
Records
Contact Us
Links/Sponsors
Home
Pony Rules
CLEVELAND SPEEDWAY 2011 RULES
These rules are for Drivers only and are not intended to impose any responsibility on Cleveland Speedway, Inc.
Cleveland Speedway, Inc. shall incur no liability to any party, whether a participant, spectator, guest or business invitee.
PONY RULES:
•BODIES ◦Home made bodies permitted. Must be stock appearing. Aftermarket nose panels are permitted.
◦1971 through 2001 models.
◦COMPACT 4 CYLINDER CARS ONLY.
◦Must have full floor pan and firewall and stock steel roof.
•ENGINES ◦Engine must be in original position (1" Tolerance)
◦Must be factory block
◦No rotary engines
◦No dual over head cams.
•HEAD ◦Steel head only. (Unless came factory with aluminum. Toyota, Nissan etc.)
◦Aluminum head cars must add 50lbs in front of firewall
◦No Porting and Polishing allowed.
◦must leave valve guide boss
•CAM ◦Solid Lift Cams Only
◦.425 lift +/- .025 for a max of .450 total lift
•VALVES ◦3/4" Machine cut only
◦Stock Valves
•VALVE SIZE LIMIT ◦1.740 intake
◦1.500 exhaust
•WEIGHTS ◦1lb. per cc
◦It is driver's responsibility to have weight clearly displayed on left front corner of roof at ALL times. Any car with weight not displayed may be disqualified.
•INTAKE AND CARBURETOR ◦Stock aluminum intake allowed.
◦Single two barrel carburetor (Modifications allowed)
•FLYWHEEL AND CLUTCH ◦Steel flywheel only 15lbs. Min
◦Single disc clutches only
◦Bell housing must have a min. of 2" hole in the bottom and 2" from the edge for visual inspections.
◦If not clutch & flywheel above you must add 70 lbs.
•ENGINE EXHAUST SYSTEM ◦Headers permitted
◦No turned down header pipes allowed
•ELECTRIAL SYSTEM: ◦Stock, dual point distributor or MSD
◦Battery must be located in a safe position.
•FUEL CELL AND FUEL - GAS ONLY ◦Fuel cell must be in a 20 GAUGE STEEL CANISTER, with 2 inch STRAPS OR WIDER and moved into rear space and must be fastened securely in a safe manner.
◦Fuel cells must be in all cars.
•SHOCKS ◦Racing shocks and wedge bolts permitted.
•WHEEL BASE ◦Stock for make and model
•TIRES AND WHEELS ◦8 inch tire width with 1/4 variation
◦Stock wheels RE-ENFORCED MAX 8 inch
◦Spoke type wheels permitted. Beadlocks OK
◦ALUMINUM WHEELS PERMITTED
◦Hoosier RC 4
•ROLL BARS ◦Steel roll over bars are COMPULSORY and must be approved. ALUMINUM AND OTHER SOFT METALS NOT PERMITTED.
◦Roll bars must be welded and must be no less than 1 1/2 inch diameter. Walls must be no less than .090 steel. No pipe fittings.
•SEATS ◦Approved bucket seats allowed. Seats should not be welded to frame but should be welded on parallel bars so the seat could shift with roll cage impact.
•BRAKES ◦Any type FOUR WHEEL DISK BRAKES allowed, except carbon fiber brakes.
•FIREWALL ◦FULL FIREWALL MANDATORY FRONT AND REAR
•SPOILER ◦6 inch or stock spoiler, mounted in original position
◦Triangular brace 12 inches long, no higher than spoiler.
•REAR AXLE ◦Stock rear end may be locked
◦No front wheel drives
◦No traction aiding devices. 90/10 shock, lift bar, etc.
IT IS MANDATORY THAT ALL CARS HAVE AT LEAST ONE 5 LB. FIRE EXTINGUISHER READY TO USE NO EXCEPTIONS.
© 2003-2011 Cleveland Speedway
All Rights Reserved.
Cleveland Speedway
420 South Lee Hwy
Cleveland, TN 37311
Phone: (423) 479-8574
Today is 09/23/2011
I run a 3/8 high banked track rf pinto spring with 1 inch spacer. rf mustang 5.0 spring with 1 inch longer arm from a 95 mustang. Lr stock spring rr elcamino spring very soft bit takes some modification of spring and body to fit. No sway bar. Stock struts Gabriel shock Lr kyb rr won 8 out of 10 races this year.
Also all of the low mustangs don't seem to work very well.
was needing to know basic spring rates and how tall of springs to run..the front has no wedge bolts but the rear does??? and how about shocks on the rear and what percentages?? just basic
