Carb.Linkage on Esslinger Intake
  • smokem2024
    • Mar 2011
    • 44
    Does anyone make those linkages or do you have to come up with something to rig...On the intake where the carb is turned around sideways...
  • Robertms
    • 113
    If you live in north Mississippi and I think you do my nephew in West Point has made several of them. You can look at one on my brother's mini stock #89, he will be running at the Mag in the next race for mini's. Actually tried it out last night a bullring. Or if you want his phone number let me know. He does not use a computer as we do. Robert Shaffer
    • smokem2024
      • Mar 2011
      • 44
      sure...ill give him a call...I think I may can make something but I have seen several I really like...
      • Racedad
        • 340
        We use a homemade bracket using a bellcrank off a Dixon lawnmower.I'll try to get you pictures, durable and foolproof.
        • dirtracer11j
          • 37
          I used the factory mustang throttle cable, cut the factory pedal off at the top where it could be bolted to my pedal where the regular rod bolts. made a tab out of a washer and welded it to my valve cover and bolted it using the factory bolthole on the cable. Works excellent and easy to deal with maintanence wise.
          • TM 44
            • Jan 2009
            • 74
            Take a stock bracket, it will bolt straight to the esslinger intake. You can make two cuts and two simple welds and it will be stong and bolt and hook up just like a stock one. Where the cable bolts to the bracket you have to turn that piece sideways and reweld. Pretty easy to do.
            • smokem2024
              • Mar 2011
              • 44
              some pics would be nice.... send to smokem2024@yahoo.com or text to 662-231-9555
